fluctuating RPM's on accel
Old 05-15-02, 01:14 PM
Lvangundy
Guest
Posts: n/a
Default fluctuating RPM's on accel
1990 LS
does anyone else notice that from a rolling acceleration, let's say from 30 to 40mph, that the RPM levels go up, then down, then up again?
For example at 30 mph, I will push the gas pedal in enough to moderately accelerate to 40. My RPM's go from 1400 to 2000, then it revs down to 1850-1900, then go back to 2000 and then car moves. This happens in about 1-2 seconds.
Now, if I do the same thing with the overdrive off, it is especially noticeable. The RPM levels actually drop even more, and it happens quicker. Like in bursts.
Anyone else notice this?
134K miles, sparks changed in 1998. Time for new ones? Any other clues?
Old 05-15-02, 01:22 PM
retrodrive
Search Function Inc.
retrodrive's Avatar
Clean out your fuel injection and check torque converter. That is where I would start.
Old 05-19-02, 09:55 PM
LSPiNoY
LSPiNoY's Avatar
Talking .........does anyone have their TPS report?
if your rpm's fluctuate and feels like tha car is jerking it could possibly be your tps(throttle position sensor)...might be wrong may be right.. anyone agree with me?
Old 05-20-02, 01:27 AM
Lvangundy
Guest
Posts: n/a
It's not really a jerking feeling, but more like just watching the RPM's move up and down on acceleration. Really weird.
Thanks for the input though.
Old 05-20-02, 05:11 AM
Petkeo
Petkeo's Avatar
I would clean the fuel injectors, and also try replacing the PCV valve, it might be clogged. The PVC cost under $10.00 and is easy to replace. I had a similar problem with my other car, and the problem went away. Plus the acceleration is much better.
Old 05-23-02, 10:27 PM
fusi0n 1er
fusi0n 1er's Avatar
Default Same Problem
i have the same RPM problem and I never drive with my overdrive off i hope it's not a big problem and I feel that jerking feeling my car has....anyone know what's up? and is it bad if I don't ge that fixed anyitme soon?
Old 12-23-04, 04:11 AM
mjanocko
mjanocko's Avatar
Try disconnecting your neg side of battery for 1 hour to reset your ECU. This will allow your computer to learn your driving habits, just like having a new car.
Lexucan
15
09-15-07 02:14 PM
Kaius88
ES - 5th Gen (2007-2012)
11-14-06 05:01 PM
AUGuy21
05-31-06 05:56 AM
aerodragon
08-19-04 12:01 PM
Quick Reply: fluctuating RPM's on accel
