Position light stays on!!!
Old 01-12-10, 12:33 AM
Daniel N
Daniel N's Avatar
Default Position light stays on!!!
Hello club lexus
I hope someone could assist me with solving my light problem!
The car is a 1993 LS.
The problem is that the Position light stays on after shutting the engine and leaving the car. Doesn't matter if I try to turn on/off the light switch arm or lock, unlock the car. They only way I can shut it of is by taken the negative battery pole off! Has anyone experienced this before?
I'm not sure that its called position light in english but here's a pic that shows the lights I'm speaking of (marked with red)
Old 01-12-10, 03:05 AM
Daniel N
Daniel N's Avatar
Further more.. I've just pulled all fuses and relays for the lights. But nothing changes, they still light up !!!
Old 01-12-10, 09:38 AM
Garage7RP
Garage7RP's Avatar
Is it connected to an aftermarket alarm system?
Old 01-12-10, 09:53 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
does your interior dome light stay on too? sounds like a door sensor died.
Old 01-13-10, 02:01 AM
Daniel N
Daniel N's Avatar
Hi guys
Thanks for the feedback
I just found the problem. It was the taillight relay! A bit tricky to get to, because its mounted above the fusebox in the cabin.
Old 04-04-10, 04:55 PM
Acidic
Acidic's Avatar
Originally Posted by Daniel N
Hi guys
How did you get to it?
luda42688
05-04-11 07:30 PM
DVac3
02-08-08 01:09 AM
LexyIS350
12-04-07 10:35 PM
vin 78
10-18-06 08:06 PM
Quick Reply: Position light stays on!!!
