Air Runner
One thing you will have a problem with if you go uas is the upper control arm not having enough travel space when you air down, therefore the front won't go too low but there is ways to fix that. I don't think you have the same problem with airrunner.
If you go for UAS or air runner the front end on a 95 -00 LS is limited by the control arm for it to be laying frame .
Lots of kits lots of parts and none of them are equal in price or parts.
Airbags are $80-150 WTF give universal air the idea to then turn around and sell them with a bracket and ask $2500-3000 never mind $2000 . It is a $1000 setup being *****d out .
Smaller lines make it lift smoothly , use less air and have a more stiff response for travel.
I think i use 1/4 and it works perfect and is just right for me since my 380 comp doesn;t get overworked trying to fill it.
If you want options to make your OEM system better , get a 5 gallon tank , mount it in the trunk a 380 viair compressor , lines and a control module from easystreet for $700 . You will now be able to make it do anything you want. If and when your oem struts go then upgrade those as well so you can do it slowly.
