No power ('92)
No power ('92)
HI sorry. Was in a hurry, it's a 1992 Lexus LS and it blew head gaskets, I'm almost done getting all the parts back in place and got the timing belt on so I wanted to check to see if it would turn over and check Compression I get all good numbers but I get no power in the car none at all
I wanted to see if it turned over and it did but I'm not getting any power no where I get horn
Compose your thoughts, organize your symptoms, spell it out, and perhaps tell us what year your car is. thanxsomuchitisdifficulttounderstandtheserun-onstreamofconsciousnessdroolsasifpeoplethinkweareinterestedindecipheringtheirpreciouscompositions
Colin
Kelley,
According to your PM, you still need help. Might I suggest you put in a little more effort in describing your exact problem of having no power. One lined blurbs is hard to diagnose. How about like: When I turn the key, there is no power. Or I put the key in without turning, and there is nothing. Or no key in, and no headlights, hazards work. See what I mean?
Also you told me you blew 3 fuses. Which ones?
Can you also share if you checked the continuity of the main fuses before proceeding?
When I turn the key i only get the light around the key and 2 fuses that have 20 on them and 1: 15, and when the key is in the ON spot; no lights come on and after I chged the fuese i got head lights and hazards without turning the key, I have not checked the main fuses with a metor but I will
