need help with ls400 (lowering questions)
Old 01-24-10, 07:18 PM
blackoutls
blackoutls's Avatar
Default need help with ls400 (lowering questions)
wassup guys im new on here and im from hawaii, can anybody help im trying to slam my car the cheapest way, u guys no of any good ideas, let me know thanks
Old 01-25-10, 09:17 PM
willhickey
willhickey's Avatar
you should say what year it is so they know the best method and have you tried the search button? 9 times out of 10 it will get you your answer
Old 01-25-10, 11:07 PM
yahoo_san
yahoo_san's Avatar
try check up with the club lexus hawaii section, maybe someone can help you locally? The cheapest suspension set up would probably be a drop spring/strut combo, but i dont think it'll get your car as low as coilovers
if you want to maintain or improve ride quality id recommend coilovers
Old 01-26-10, 02:12 AM
blackoutls
blackoutls's Avatar
thanks guys its a 1992 ls400
Old 01-26-10, 03:18 AM
LiCelsior
Retired
LiCelsior's Avatar
megan coilovers.
Old 01-26-10, 04:31 AM
Li Ls4
Li Ls4's Avatar
+1 for megans
Old 01-26-10, 06:54 PM
BIGGZ
BIGGZ's Avatar
Not the cheapest way,but coilovers is the route you should take.you could do regular drop springs but it wouldn't be as low as if you were to use coilovers.but the cheapest way would be to cut your stock springs,or take them out completely.**not recommened**
Old 01-26-10, 08:38 PM
mista808
mista808's Avatar
cheapest, cut the stock springs.... that would be the cheapest... next cheapest, dropped springs-will run you about $250+... after that is coilovers...
Old 01-26-10, 08:49 PM
Do.Man
Do.Man's Avatar
megans, its worth waiting a lil longer and save up then cut springs and etc.
Old 01-28-10, 07:32 PM
My1998LS40
My1998LS40's Avatar
I heard somewhere that you can even heat up your spring to get them lowered. Old school people did that to their cars way back when there is no aftermarket parts for them. But, I'll go with everyone else on the coilovers.
Also, while we at it, I saw people also use airbags with the coilovers. How is this work? Do the airbags replace the springs on the coilovers? This is what I'm looking into because I do want to lower my car to the ground when parked, but do want to raise it up so I can drive comfortably.
Old 01-28-10, 08:18 PM
TBone12
TBone12's Avatar
if your looking for something cheap, bags are not the way to go.
istundra
Suspension and Brakes
26
09-17-10 12:48 PM
1Bentley
55
10-09-09 12:52 PM
tonysgs300
07-28-09 07:47 PM
slamgrayls
04-26-08 09:31 PM
ATSOU
03-06-02 03:04 AM
Quick Reply: need help with ls400 (lowering questions)
