90 LS400 Possible Starter or Electrical Issue
Old 02-12-10, 03:42 PM
dbullen
dbullen's Avatar
Default 90 LS400 Possible Starter or Electrical Issue
90 LS400, when you turn the car over sometimes you hear a click, or sometimes the starter will crank for a couple of seconds and then dies, and all lights go dead in dash until you return the key to normal position.
Does this sound like a starter issue or electrical problem?
New battery, terminals are secured tight and are clean.
dbullen is offline
Old 02-12-10, 03:44 PM
LiCelsior
Retired
LiCelsior's Avatar
sounds like the starter is starting to go! haha get it
LiCelsior is offline
Old 02-13-10, 08:43 AM
dbullen
dbullen's Avatar
HAHA! I bypassed the relay and connect 12v directly to starter, got a few cranks, sometimes clicks, then got it to crank for 10 seconds or longer, but car wouldn't start, but starter still didn't sound good, would it be possible that it just wasn't cranking fast enough to start the engine? Gonna replace the starter I guess and go from there.
dbullen is offline
Old 02-14-10, 06:51 PM
AzHotLS
AzHotLS's Avatar
Sounds like you've already tried diagnosing the problem, so this may be redundant:
How To Diagonse Faulty Starter
AzHotLS is offline
Old 02-14-10, 09:20 PM
JimsGX
JimsGX's Avatar
Start by having the battery and alternator output checked before moving over to the starter. Also, make sure the battery terminals are clean and tight. If you search you'll find threads about starter replacement. It's a PITA job and unless you DIY, it can be expensive.
Jim
JimsGX is offline
PickupStix
06-19-16 11:12 AM
Maik04
Performance & Maintenance
03-10-15 07:57 PM
tlewis
02-14-14 02:46 PM
stk7741
09-12-11 01:19 PM
b1gredek
10-07-04 08:45 AM
Quick Reply: 90 LS400 Possible Starter or Electrical Issue
