ive been trying to take out the old one but it doesnt want to come out, do i take the whole block off?
ive tried to use some needle nose to try to pull it it out, but all it does is chip the clear casing on the top. i dont want to pull real hard because my whole fus box moves with the fuse.
how would go about pulling it up?
Shortly after buying my LS 6 years ago, I learned that some not so bright guy had hard wired the 120A circuit in place of the fuse. I think they probably couldn't figure out how to pull the fuse out, so they soldered a piece of wire in the old fuse itself - this was completely hack and potentially very dangerous, so I was glad I spotted it. I remember buying the fuse at either autozone or pep boys - it should be available anywhere. I do recall having to remove screws on both sides of the fuse and then being able to remove it - it took some patience, but wasn't so bad. Thankfullly, I haven't had any electrical issues related to that since.
