Climate control display - can 93 fit in a 91 Ls400
Hi I'm a newbie can some tell me if a LS400 93 Climate control display - fit in a 91 as mine is dark?
thanks
Allen
thanks
Allen
![Thumbs down](https://www.clublexus.com/forums/images/icons/icon13.gif)
NO, it will not fit your '91 LS.
I have a '93 LS and tried to install a '92 unit.
I bought one from a salvage yard and thought it would
work. I tried to install it and found out the plugs in the back
did not match!
You need to get one from the '90, '91, or '92 model years.
Look at the front of the display, the temp. and clock are
not separated:
The '93 and'94 models have a separated temp and clock:
Check out the thread below:
https://www.clublexus.com/forums/sho...threadid=17576
Good Luck.
did not match!
not separated:
Good Luck.
LScowboyLS
26
04-25-16 03:49 PM
