Timing Belt - Dealer Vs. Independant
Super Moderator
Wayy back in '06. Parts rounded up to the nearest dollar:
T Belt $65
W pump $126
Crank seal front $9
Cam seals $14
Tensioner $50
Tensioner pulley $123
Idler $76
Coolant $20
water pump O-rings $6
oil pan gasket $13
Spark plug wire set $125
Rotors $19
Ignition caps $42
$1,114
The dealerships were running $1,300-$1,500 for lesser parts replacements. This shop did it all. I installed the plugs myself.
T Belt $65
W pump $126
Crank seal front $9
Cam seals $14
Tensioner $50
Idler $76
Coolant $20
oil pan gasket $13
Rotors $19
Ignition caps $42
$1,114
