Replacing front shocks on 99 Lexus 400LS
Old 03-04-10, 06:53 PM
tomrctmal
tomrctmal's Avatar
Default Replacing front shocks on 99 Lexus 400LS
How difficult is it to change the front shocks on a 99 Lexus 400LS? Is this a job that can be accomplished by a novice with reasonable mechanical skills working in the driveway? Tom
Old 03-05-10, 07:20 AM
Hils400
Hils400's Avatar
It is not too bad. Just remember to get the spring compressor and compress spring before removing the shock from the assembly. Otherwise you could get hurt from a flying part. I thought the hardest part was the time and effort to compress the spring. Otherwise it is pretty much unbolting and bolting back up. And alignment.
Old 03-05-10, 08:16 AM
justinp95
justinp95's Avatar
Look at my thread. Its a few threads from the top. Same process.
Old 03-05-10, 08:24 AM
amcdonal86
amcdonal86's Avatar
Yes, it can be done. However, compressing the spring with a spring compressor sucks!!!!! That will probably take two people unless you have a table clamp to hold it down.
amcdonal86
amcdonal86's Avatar
BTW, if you are going to change your front shocks, you might as well replace the upper strut mounts ("top hat").
Old 03-06-10, 08:15 PM
19psi
19psi's Avatar
yes, very easy. should not take more than an hour and 15 minutes.
Old 03-06-10, 10:09 PM
RA40
Super Moderator
RA40's Avatar
"Struts"
UNCJD
13
09-16-15 09:17 PM
trhs75
RX - 1st Gen (1999-2003)
07-20-15 05:21 PM
biodev
10-23-10 06:44 AM
whatthe
GS - 1st Gen (1993-1997)
12-01-06 06:13 PM
Quick Reply: Replacing front shocks on 99 Lexus 400LS
