Brake Issues ?
Old 03-12-10, 08:11 AM
V.I.P LS4
V.I.P LS4's Avatar
Exclamation Brake Issues ?
I have a 1995 ls400 with 169k on it . My front brakes keep making a cracking noise in the front and a loud gripping noise , the pad wear and rotor are fine. The only thing i can think of is that I need the Oem Shim Kit ? i took apart the brakes like 3 times and put brake quiet on there etc. One of the Pistons has a torn rubber boot slightly. The next conclusion i have is that the Pistons are giving out or my master Cylinder is giving out ?
Anyone have this issue before , or any suggestions
Thanks
Old 03-12-10, 09:29 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
do they make the noise when ur stopped/not moving but just pressing the brake pedal?
you need a shim kit anyways, and that caliper with a torn boot on the piston needs to be rebuilt before it totally seizes up.
if you fix both of those problems and still have that noise then you should replace the strut bar bushings, as its a common symptom of badly torn bushings.
Old 03-12-10, 09:43 AM
LiCelsior
Retired
LiCelsior's Avatar
i gots a 2LS brake caliper rebuild kit for sale!
Old 03-13-10, 08:42 AM
V.I.P LS4
V.I.P LS4's Avatar
Puredrifter , yes it happens when im stopped in place and just holding the brake down too, Can i replace just that rubber boot on that piston ?
Li Celsior , how much are you asking .
Old 03-13-10, 03:41 PM
PureDrifter
BahHumBug
you have to rebuild the entire caliper, the torn bushing means that there is already crap inside the hydraulic system. i would rebuild that caliper and flush the whole system.
if there's still noise after all that, replace the strut rod bushings.
Old 03-13-10, 07:03 PM
LiCelsior
Retired
LiCelsior's Avatar
sorry just sold it, i have someone local thats coming to get them.
Old 03-14-10, 11:00 AM
V.I.P LS4
V.I.P LS4's Avatar
Puredrifter: i changed the pads and there is no more noise , i guess it was the shims that werent on there, but there is a small cracking noise from one of the pistons , im gna buy the kit and do it its 25
25 $ , not bad. Thanks
Old 03-14-10, 12:23 PM
fixedright
fixedright's Avatar
Thanks
Old 03-14-10, 03:43 PM
V.I.P LS4
V.I.P LS4's Avatar
i will let you know Thermactor .
Fixedright ?
Blaksilver
Wheels, Tires & Brakes Forum
12-30-18 04:54 PM
GoHuskers
NX - 1st Gen (2015-2021)
08-30-17 07:37 AM
20012003rx
06-01-14 09:57 PM
pitmanr200
Suspension and Brakes
04-22-08 09:45 PM
LesMan
01-16-08 03:40 AM
Quick Reply: Brake Issues ?
