No Spark
Hey Guys,
I just replaced the waterpump and timing belt in my ls400. After, make sure everything is lined up correctly. I put her back together and now I'm not getting a spark. She has gas in her but when a try to turn her over it sounds like there is no gas. I checked the distributor rotors, sparkplugs and the battery, Any suggestion place help?
Hey Guys,
I'd start with the pass side coil... there should be the spark plug wire and the little electrical connector into the back of it...
Have you pulled a plug and tested to see if you are getting spark?
peterls
11-17-13 06:48 PM
One HoT
SC- 1st Gen (1992-2000)
06-26-03 08:04 AM
