Stereo Install...
So I got my single din install kit for my LS400 today! But, I'm missing that part off my stereo that you bend up to position the head unit... (generally they come with the head unit). Where do I get a new one? Hell I don't even know what its called. Anyone got any ideas or suggestions on this problem?
so my wiring harness (87+ toyota) doesn't work with my lexus uggg I have a nak system... what do i do...)
cage! thank you sooo much! Now I wont sound like a idiot... uhhh that metal thingy that wraps around this metal thingy that bends up to stop this big metal thing from leaving the plastic thingy...
wohoo carefully soldered in all my connections for ultra low resistant connection! tomorrow If all goes well with me being not as sick... I should finally have my head unit installed!
You really meant the sleeve? Come with the headunit out of the box to hold the HU secure in place. Has little tabs that can be bent up to keep it in place. Yeah, most of the stereo shop would have those laying around. Because in most of the Nissan, Mazda, Mitsubishi and some newer Honda, you have to take that sleeve off and bolt the HU directly to the metal brackets.
I CANT cut anything in the car, just a little preface, this car was my grandmothers (R.I.P) and it has to be able to return to stock...
will this work for me?
http://www.crutchfield.com/p_1207081...g-Harness.html
I would like to keep the stock amp (maybe upgrade it in the future if thats possible)
i have the 87 + toyota wiring harness that was "supposed" to work but since i have the Nak system... it doesn't but from what i gather the one i posted above should take the unamped signal from my Head Unit and send it to the amp...
did no one look at the harness up there??? it takes 4 RCA's into the harness and supplies power... and again i want to keep this thing as close to stock as possible...
y not find a wiring diagram for the nak system, take the prongs out of the aftermarket harness and rearrange them into the right spot on the plastic conecter so that u dont have do cut and reattach all those wires
