please help!!
please help!!
i just put on the 20 inch rims.. the tires in the rear is totally scraping the fender and its messing my my tires.. i was lookin at the way the fender is made.. it seems like i can either roll it inward or cut it complete off.. can anyone give me some suggestions? if it wasn't for the peice that goes inward i would be clearing just fine but the fender seems to have a peice on the inside and that is totally messing me up.. please help!!!!!
its 8.5
the offset is +38 i think and the tire comes out a lil too much.. so when the car goes into a dip it rubs all over the inner side of the fender..
what u guys think i should do? cut the extra out?
its rubbing with 8.5
my car is lower 2 inch .. and the tire sticks out of the fender.. in the back.. not the front for some reason.. when you say roll the fender ? how would i go about doing that? here is the pic of the rims on my car..
on the verge..
i am on the verge of putting the car back to stock hieght.. what do every one think of my idea of putting the car back to stock height? i am sick of it rubbing.. i was told if i put the car back to stock height since the rims is 20 inch.. the gap won't even be that big anyway.. smaller gap then if was to put the orginal wheels on there.. its that true? should i put it to stock height?
please give me suggestion..
stock springs on 20's.. what do you guys thinK?
before you raise it up, can you take a photo of where the tire is rubbing...+38 should not rub...could be that the offset isn't correct on the wheel...(even though it may be stamped +38)...this is why you need a offset measuring tool
manray
yea ur right the offset is wrong and the tires is stickin out way too much.. i have no other choice.. i was told its 38 offset.. but it can't be cuz the tires is out too much.. any suggestionS?
let me also add that the only reason why the tires is hitting cuz the car is too low.. its dropped about 2 inches.. i think if i drop one inch with the ibach kit it would not rub.. what do you think on that one also?
here is the pic with HID and rims..
In your case, I would just have the fenders rolled...take it to a competent wheel shop and they can do it...they should have a machine that does it (not a baseball bat)...they can also hammer it (if the guy doing it knows what they're doing).
I would MUCH rather do that than to raise the car up...
BTW, you need a body kit...BAD!
manaray
i can have the back rolled.. but the front is so low.. and there is nothing to roll.. and the tire sticks out cuz the offset is wrong.. either way i am screwed.. what other ideas.? i was thinkin i should just get the 1 inch drop and slam those in.. get it all right.. right now is 2 inch drop.. the car dont ride like it suppose to.. what do you think?
paulwall4
RC F (2015-present)
15
09-25-17 02:12 PM
melski415
08-21-11 05:56 PM
BlackSC300
SC- 1st Gen (1992-2000)
09-16-01 05:26 PM
