Help~ blowing smoke
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
hi, my 94 ls400 , done 170000kms , recently just starting blowing white smoke, when i try to rev it, got more grey or blue smoke coming, the engine seems nt running on all the cylinds, and i gv headgasket test, it seems all good, nt use any water, engine oil very clean, i also clean the throttle body and check plugs, theyre fine. no engine check light on the dash.
anyone got same problems before or anyone can tell me whatelse could b wrong?
thx a lot!
thx a lot!
If it's white smoke then your probably getting water into the intake/combustion chamber(s). Did you drive thru any deep/standing water and force some into the intake?
I don't follow the logic from garage7 if I understand correctly ta2 is saying that there is no evidence of power steering fluid in the vacumm lines so how does that mean that it is leaking? I would say the opposite.
Ta2 figure out where the power steering fluid is going. Do a search on the control valve (its all over this site ) and then figure out if that is the issue. I would think there should be evidence (traces of ) power steering fluid in the vacumm line. Maybe check it after the car has been sitting for a while before you start the engine
