Inexpensive 90 LS Brake Upgrade?
#32
I am needing to do this soon as well. I just got a 1992 LS400 and the pads look a bit worn, and the same with the rotor.
I plan on doing a full rotor and pad replacement as per LiCelsior's advice here in the new few weeks, just need to get paid! I will give you some feedback once I have done it if you are still thinking about it Sebass.
#36
My 93 Celsior came with pretty low milage and more or less perfect brakes. For what they are, I think they are quite powerful, I can't imagine needing 4piston brakes on a car that has 250hp, 4 piston brakes are more for fade resistance then overall stopping power. (I've owned 4 supras and have a 4 piston 3000gt)
#37
Great support forum here guys. Lot of info shared here.
Is it fair to conclude that single piston caliper on 90 is insufficient based on what i'm reading here? I had dual piston on my 91 ls and breaking power was still not sufficient so i thought!!! But then again i don't think i used premium pad and fluid probably was old. Don't remember it was change in 7yrs.
I just can't imagine changing fluid will help in any way???
@JimsGX. I had previously 91 ls and calipers were sizing up like you mentioned in your post. Mechanic at the time changed the break rubber hose which i believe resolved the issue. Later issue came back but i wasn't sure if it was same side or other side since other side was untouched. So little scared to change dual piston due the seizing issue i had before, even though i think it was rubber hose causing piston to seize not the pistons itself seizing but you might be right about swelling and lubrication. I simply do not know enough about it besides the fact I wouldn't want to invest in dual pistons and had the issue reoccur on me. I doubt that would happen on new calipers tho, instead of used onces.
@Kansas. Great idea with wheel size. At my next tires change i will change it to 225-60-15. I don't get why you saying it will be harsh. It's only 5 down from 65. It's not like they're low profiles 45's. I also feel that tire size is insufficient stock.
I think i'm going to try to address issue first in two fold.
1. Change break fluid. Can i just pump out 3/4 of fluid from reservoir and replace it with new fluid and do same thing again a week from now therefore changing the entire fluid since it will mix ...right ? Don't want to bleed until next break job.
2. Change pads to Hawks HPS's. Seems like a lot of you like it here. Friend recommended Axxis ULTRA but they're slightly more expensive.
3. So i can use 91-92 dual pistons without any mods on 90 ls right?
Can i also use 91-92 rotors. Were they slightly bigger?
Looks like rockauto has good price on dual piston.
#42
Maybe PD would know if your aftermarket rims will fit with the four piston calipers, but if I were a betting man, I'd say the PO switched to the single piston calipers to get his rims to fit because they wouldn't fit over the four bangers...
MIGS
14
02-09-14 07:26 PM
