95 auto window function not working
Hi fellow CL'ers,
My quest to find out why my auto window function does not work on my 95 ls4 is not going so well. The other windows will not rolll down with the drivers switch. I thought it was the switch, so I replaced it with another. Same problem exists. Is this a common problem with the switches or is there an ECU that needs fixing? All windows work on their own switch. They just can not be controlled by the driver control switch. Any Ideas?
in the driver's door, good one Mr. Obvious.
Diagram:
http://www. t o y o d i y .com/parts...KA_8401.8.html
(remove spaces from t o y o d i y)
Diagram:
Diagram:
Diagram:
Thanks for all the replies. I will check the door harness before I order the ecu. hopefully my rat enemy hasnt chewed through that harness as well. Never know with that guy. He has cost me well over $1000 in wiring issues. He made a nice nest under the intake manifold, chewed through the injector wire harness, pcv hose, ate the egr harness to include the connector, and also ate the left knock sensor connector and pigtail as well.
I hope that I have found all the damage and can drive this car.
Archi
RX - 1st Gen (1999-2003)
04-18-18 01:26 AM
