Headliner Removal, rattling from behind your head
Old 04-03-10, 06:35 AM
Acidic
Acidic's Avatar
Default Headliner Removal, rattling from behind your head
I dropped my headliner for several reasons yesterday. For one I could hear rattling from behind my head, putting my hand on the headliner right behind me would cure the sound... Secondly I could see the headliner clips along the back window had separated. I thought the two might be related but once I got in there I found the real problem...
At the back of sunroof track inside the drip pan there is a clip riveted to the plastic that holds the back of the track on. The rivet had broken causing the clip to rattle against the track... I tried to use rivets to fix it but it would have required dropping the whole assembly and removing the sunroof racks so I used a bolt instead. I grabbed a few pictures of the whole thing that I'll post.. I could never find good pics of what everything looked like above the headliner..
I also blew out my drains while I was in there and fixed the sagging headliner. And then DISASTER STRUCK... I was humming along putting things together and I cracked my sunroof glass... So I'm looking for that BTW ASAP! If you have a spare let me know...
The second pic down is back of the track with the clip taken out... that's where the rattle was coming from...
Attached Thumbnails Headliner Removal, rattling from behind your head-img_5462.jpg   Headliner Removal, rattling from behind your head-img_5459.jpg   Headliner Removal, rattling from behind your head-img_5451.jpg
Old 04-03-10, 06:36 AM
Acidic
Acidic's Avatar
And here is some pics for anyone who wanders in here looking for sunroof leaks, rattles etc of what it looks like above the headliner... etc...
Attached Thumbnails Headliner Removal, rattling from behind your head-img_5444.jpg   Headliner Removal, rattling from behind your head-img_5445.jpg   Headliner Removal, rattling from behind your head-img_5446.jpg   Headliner Removal, rattling from behind your head-img_5448.jpg   Headliner Removal, rattling from behind your head-img_5452.jpg
Old 04-03-10, 08:01 AM
amcdonal86
amcdonal86's Avatar
Thanks for sharing!
I guess the sunroof glass isn't tempered?
Old 04-03-10, 09:01 AM
Acidic
Acidic's Avatar
I was being stupid and was using the glass as a lever point for a clip puller and put way too much pressure on one spot... I just wasn't thinking
Old 04-03-10, 10:50 AM
TRULUX
TRULUX's Avatar
Ouch! Sorry to hear about your bad luck! Trust me all of us that work on our own cars have done stuff just like that. I know I sure have when right after it breaks you say to yourself how could I have been so stupid? Lol I feel your pain. I once dropped an Allen wrench inside my bell housing and had to drop the tranny to get it out. Good luck!
flaco1801
flaco1801's Avatar
can you see the rear drain lines from underneath the car when its on a lift? where do they empty.... thanks, jeff
Old 04-03-10, 01:19 PM
Acidic
Acidic's Avatar
Yah you can see them... the easy way to find them is to poor water on the roof and it'll puddle up under the drains... The front ones come down around the steering rack IIRC, the rear ones I'm not sure of... just poor water in and watch I suppose... A good way to get water back there is to park on hill, put the roof part way in and poor water onto the glass... that will get the water to run back to the drain lines...
Old 04-03-10, 01:21 PM
Acidic
Acidic's Avatar
thanks... It seems to happen on most big jobs I do... I do 95% correct and then screw something up that takes an extra couple of hours to fix...
Old 04-03-10, 02:10 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
i wouldnt put the headliner back til after you fixed that...its going to be a pain since you have to take the entire assy. off before replacing the glass.
Old 04-03-10, 03:32 PM
Acidic
Acidic's Avatar
I don't know about Gen 2 but on the Gen one you don't have to take anything out to replace the glass... Just two trim pieces covering 6 nuts... it's simple as simple as putting air in your tires... unless of course you break the glass trying to pry off one of the trim pieces...
Old 04-06-10, 09:26 AM
steveski
steveski's Avatar
Sorry - reading at work - so did your rattle get remedied by tightening a support? I have the same damn rattle and it drives me nuts.
Old 04-06-10, 03:31 PM
Acidic
Acidic's Avatar
The rear support for the sunroof track is a metal bracket that is riveted to the drain pan (plastic) which is right over the pass seat cushion area. I replaced it with a nut/blot because I got impatient with the rivets...
BTW I'm still in need of sunroof glass
Old 04-14-10, 10:07 AM
DK Audio
DK Audio's Avatar
I too have the annoying rattle. I wish here was an easier fix than taking off the entire headliner which I am kind of hesitant to do...
Old 04-14-10, 05:32 PM
Acidic
Acidic's Avatar
It's not that bad... I've done alot of audio work though so disassembling the interior is something I feel comfortable with and is generally error free... if it wasn't for the fact that I got a little careless at the end and if I had the objective of fixing this in the first place it would have been 2-3 hours tops...
Old 04-19-10, 01:23 PM
steveski
steveski's Avatar
Thanks - I will add this to my to do list as it seems like I could get it completed minus the sunroof tho
BTC89LS400
12-17-18 09:44 AM
ThomasH95
10-19-16 06:50 PM
skassamali
08-28-11 05:32 PM
Feirax
03-24-09 10:36 AM
jtgs400
04-24-08 11:37 AM
Quick Reply: Headliner Removal, rattling from behind your head
