1990 LS400 help
1990 LS400 help
Hey guy i need some help again
i need to know what are some descent replacement speakers for a 1990 ls400 (size and brand would be great) i only have one working.
?2 i have the factory radio can i hook up a subwoofer to it?
?3 i would LIKE to change THE ignition LIGHT & interior lights to LED. I need to know what type of lights to buy i would like to have a blue-ish type light
?4 the bottom of my passager door is ****ed up (the black part at the bottom) how would i fix that?
?5 the last one!!!! The interior on the passager door is curling away for the door how do i fix that?
Please help me im new to this. And this is my first car/lex.
Let me see if I can answer a few for you.
Speakers,,the first gen 89-94 came with only a 4" speaker, so your choices are limited. If you are fairly proficient with a dremel, then you can widen the hole in the speaker baffle and fit in a 5.25" speaker (I did this to my 92).
Radio,,, YES you can hook a subwofer to it, HOWEVER you will need an aftermarket amp and you will have to go thru the process of bypassing the OEM amp in the car. The factory radio (from what I understand) will not work with the amp completely removed, as it is part of the system, but it WILL work if it is bypassed.
Lighting,, this has been discussed several times before, and there is NO one simple answer. Use the search feature here in this forum and putin the key work LED lighting in the LS section of the search feature. A few threads should pop up and you can go from there.
Black trim,, looks like it took a small hit,, may want to find a donor at the local boneyard. Crazy Rays(depending on what part of MD you're in) has plenty of them.
Curling,, your pic looks ,to me, like that back door panel wasnt put on correctly and was just forced into place. May be something as simple as removing the panel and reinstalling. If it is peeling from the base panel, then you may need to re-glue.
What part of Md are you in?
Oh,, and BTW,,,,www.lexls.com is gonna be your friend for ALOT of info.
VolVette
02-16-06 01:46 AM
