Any idea where engine speed sensor is?
Old 04-08-10, 10:25 PM
ck90211
ck90211's Avatar
Default Any idea where engine speed sensor is?
Need help on locating the engine speed sensor that sends signals to the tachometer. Just installed a salvage engine into a 96, and everything working great, except tachometer not responding. Before I pull out the instrument cluster to diagnose, perhaps it would be a good idea to make sure this engine speed sensor is plugged in right (or functioning).
Thanks in advance.
Old 04-09-10, 05:18 AM
williamb82
williamb82's Avatar
the tach signal comes from the ignitor. if it wasnt plugged in then the engine would be running like crap. there are 2. 1 for each cylinder bank. so its either a wiring problem or the tach is bad. if the tach worked before id check every connector on the engine harness asuming you used your old harness. if you used the one that came with the engine could be a bad wire.
Old 04-09-10, 09:23 AM
ck90211
ck90211's Avatar
Thanks Williamb82, it was working before. And yes about engine running crap if there weren't any engine speed signals. Will get multimeter out to diagnose/find bad wires.
Added: After a longer drive tachometer is alive again. Probably a less-than-good connection somewhere when putting the engine back in.
Old 04-09-10, 11:37 AM
williamb82
williamb82's Avatar
yeah, prolly just have a plug that had a bad connection due to too much dielectric grease in it or something. at least you didnt have to go chasing wires. that can be fun. lol. heres what my 84 looked like when i built the engine harness for my megasquirt 2.
http://www.cardomain.com/ride/2042690/18
Old 04-09-10, 02:34 PM
3UZFTE
3UZFTE's Avatar
Does the Tach signal come from the cam position sensors?
Old 04-12-10, 08:24 AM
williamb82
williamb82's Avatar
no. ignitor. or if for some reason your wanting to install an aftermarket tach you can grab te signal from the neg side of either coil. just make sure that your tach is set for a 4 cyl, not an 8 cyl. each ignitor/coil is running half the engine only.
Old 04-13-10, 06:05 AM
williamb82
williamb82's Avatar
Originally Posted by Thermactor
whoa, mr. celica supra! Great to have you in the LS section!
lol. didnt know you had an ls. just got mine a few weeks ago. still sorting some issues out. needed a new daily so figured id get a 1st gen ls400 and ride in style and comfort. and the bigger rods incase this car gets the turbo bug too!
anx4evr
Performance & Maintenance
13
09-19-13 08:48 PM
Tjfaz
03-10-13 12:52 PM
jomidan
Maintenance
06-28-11 05:31 PM
jomidan
SC- 1st Gen (1992-2000)
06-27-11 08:23 AM
frankjames
RX - 1st Gen (1999-2003)
12
09-02-09 11:02 AM
Quick Reply: Any idea where engine speed sensor is?
