Smelly musty air when starting A/C
Old 04-09-10, 04:43 PM
amcdonal86
amcdonal86's Avatar
Default Smelly musty air when starting A/C
Hi, I'm experiencing some smelly musty sour air coming out of the vents when I first start the A/C. I cleaned out the air filter and it didn't seem to help (there was not much trapped in it anyway). Is there anywhere else to look? Perhaps any place to check for clogged A/C drains?
Old 04-09-10, 05:51 PM
sam12345
sam12345's Avatar
There is a rubber hose that points to the ground under the car. When the air conditioner is on you should see water drip out of it (especially on a humid day) if not your drain is clogged
Old 04-13-10, 01:21 PM
steveski
steveski's Avatar
I bought an air conditioner spray that kills mold, mildew, etc. I spray it in the inlet under the hood, etc. every 3 months. You could probably find it at your hardware store or maybe even a discount store.
Old 04-14-10, 09:41 AM
willhickey
willhickey's Avatar
they got it at autozone and advance
Old 04-14-10, 10:27 AM
KMinAF
KMinAF's Avatar
During my short tenure working at the local Toyota stealership as a service advisor, I was told to sell the A/C service for $35.00. The service consisted of lifting the hood for access to the heater air intake and spraying a liberal amount of Lysol disinfectant spray directly into the the cowl vents while the heater fan was running on high.
This was done to to kill the mildew that sometimes builds up inside the evaporator case.
Another bit of advise is to run the A/C in the fresh air mode as much as possible as this keeps moisture from accumulating on the evap coils.
Old 04-18-10, 01:31 PM
amcdonal86
amcdonal86's Avatar
Well, sure enough there is no water dripping from my car with the A/C on. I saw what appears to be the drain for that near the exhaust system in the front of the car. I used a little pipe cleaner (actually that $10 one on the infomercials) and could not get it to drip water.
Is there another way to get to it? Or perhaps this is the wrong drain?
Old 04-18-10, 01:36 PM
LiCelsior
Retired
LiCelsior's Avatar
change ur cabin filter.
Old 04-18-10, 01:43 PM
amcdonal86
amcdonal86's Avatar
Changing the cabin filter will not fix the fact that there is no water dripping under the car when there should be. Checking the cabin filter was the first thing I did, and it looks relatively free of debris, although it could probably be changed.
Old 04-18-10, 02:00 PM
97CE LS400
97CE LS400's Avatar
Do have a pics where these cowl vents are. I had a musty smell to...but since I had just had my coolant flush it's not as bad
Old 04-18-10, 02:16 PM
amcdonal86
amcdonal86's Avatar
They are on the passenger side right under the windshield wiper/bottom edge of windshield, I believe.
Old 04-19-10, 12:37 PM
steveski
steveski's Avatar
The spray is maybe $5 at a parts store - spray it into the inlets under the hood by wipers with A/C on max. - you will see that smell will be gone. I would also spray the cabin filter as it will kill the mold spores, etc. Cheap fix
Old 04-19-10, 04:40 PM
amcdonal86
amcdonal86's Avatar
Does anyone have a diagram of the A/C system?
Old 04-20-10, 08:13 AM
steveski
steveski's Avatar
I have factory repair manuals but can't make a copy to scan until tonight - unless somebody else posts one (BTW it is for 95).
Old 04-20-10, 08:23 AM
amcdonal86
amcdonal86's Avatar
Thanks steveski. I really appreciate that. '95 should be the same as my '97.
Old 04-20-10, 08:28 AM
steveski
steveski's Avatar
I will make copy of main page showing diagram and scan - I may do more than one page to make sure you get what you need.
Quick Reply: Smelly musty air when starting A/C
