93 lexus ls400 oil leak!! Help!!
Old 04-14-10, 07:39 PM
jallow33
jallow33's Avatar
Red face 93 lexus ls400 oil leak!! Help!!
Hello, i am new to here!! I have a 93 lexus ls400(167k) that has a small oil leak under THE CAR for about a week now. Just did the timing belt 2 months ago in february(165k) with new oil pump(hole cracked where it holds tb tensioner), seals and tb tensioner and plugs, rotors, distributors, etc...recently my car was put up on a lift and the guy inspecting the car under says you have a small oil leak, it is coming out of a SMALL HOLE OF A black plastic box right above the oil pan. When car is parked for about 20 mins or so, it is a small drop of oil and that is it, no addt'l oil comes down. The oil from the week so far has only dripped onto oil pan and has not spilled all the way back on manifolds, cats, etc... Can this be the front main seal so soon leaking after being replaced 2 months ago? If so, can i get it to it under the car rather than going through the whole tb replacement procedure? That procedure was very long and is a pain the a**. Would appreciate any feedback, thanks!
Old 04-15-10, 08:28 AM
Boyscout
Boyscout's Avatar
black plastic box on which side of the oil pan?
Old 04-16-10, 11:14 AM
jallow33
jallow33's Avatar
Its above the oil pan, small black plastic box, the bottom of the timing belt
bdpride04
10-31-17 12:59 PM
Hacc
13
06-09-17 08:09 AM
peaceboi
12-27-10 10:13 PM
Och
12-25-07 10:33 AM
Pagong
11-28-03 11:39 PM
Quick Reply: 93 lexus ls400 oil leak!! Help!!
