Wheel HELP in NY
Not sure what PAD Height means, but Offset/Width info is generally for knowing Clearance of suspension components and outer fender clearance, so yes your right if you guys say 18x8.5 +45 will fit regardless of spoke design all i need to figure is if the spoke design will clear the Brakes
an 8.5 +45 will fit with 0 issues in all clearance aspects besides brake clearance.
what is commonly referred to as "disk type" is a combination of pad height (the area that bolts on) and spoke design. a high disk (bbk clearance) will generally have a thicker pad or will sometimes have spokes with convex curvature to clear the brakes. so an 18x9.5 +45 super low disk will not fit, whereas an 18x9.5 +45 high disk will.
therefore, with the given set of parameters, diameter, width and offset are meaningless. you can not go by another car that fit these specs because brake clearance is the only issue.
don't really need a lesson in wheel measurments... thanks though.
