Wheel HELP in NY
Old 04-16-10, 02:23 PM
porn-adkt
porn-adkt's Avatar
Default Wheel HELP in NY
i need to know if the wheels i have will fit and clear stock suspension and Brakes on a 96 LS400.
If some one around the lower NY westchester area with a 96LS400 (2nd gen i think) can let me dry fit my wheels on your car i would appreciate it.
in exchange ill buy you lunch
thanks
Old 04-16-10, 02:28 PM
LiCelsior
Retired
LiCelsior's Avatar
brakes i have...stock suspen..nope
Old 04-16-10, 03:04 PM
Li Ls4
Li Ls4's Avatar
same here have the breaks but dropped on coils, not slammed or anything barely tucking tire
Old 04-16-10, 03:07 PM
porn-adkt
porn-adkt's Avatar
Damn.. well. maybe you guys would know if a 18x8.5 +45 fit with stock suspension? if yes then i just need to confirm that it clears the Brakes.
i have stern st-5 and the spoke design is kinda sunken in. it clears my 2nd Gen GS.
thanks
Old 04-16-10, 03:41 PM
LiCelsior
Retired
LiCelsior's Avatar
that should fit fine. the LS430 reps i have are 18x7 +45 and they clear....but it depends on the backspacing also.
Old 04-17-10, 09:58 AM
SRV1
SRV1's Avatar
LS430 have similar design calipers of that of the 96 LS4. GS calipers are only dual piston.
James
Old 04-17-10, 10:01 AM
porn-adkt
porn-adkt's Avatar
where in LI are u?
Old 04-17-10, 10:14 AM
LiCelsior
Retired
LiCelsior's Avatar
Nassau County, Long Island.
Old 04-17-10, 10:31 AM
BLKonBLK98
BLKonBLK98's Avatar
don't be a dummy... it depends on pad height. width, offset, backspacing, etc. are meaningless.
Old 04-17-10, 10:54 AM
porn-adkt
porn-adkt's Avatar
Damn..
ANY ONE CLOSER to Manahattan?
Old 04-17-10, 10:59 AM
porn-adkt
porn-adkt's Avatar
Not sure what PAD Height means, but Offset/Width info is generally for knowing Clearance of suspension components and outer fender clearance, so yes your right if you guys say 18x8.5 +45 will fit regardless of spoke design all i need to figure is if the spoke design will clear the Brakes
Old 04-17-10, 06:01 PM
j three
j three's Avatar
I remember Jason05 had some stern wheels a while back on his first 2LS and they did not clear the calipers without a spacer.
Old 04-17-10, 06:18 PM
SRV1
SRV1's Avatar
Did he have any fender lip issues when he used the spacer?
Thanks, James
Old 04-17-10, 06:39 PM
j three
j three's Avatar
I'm not sure but you can look him up and pm him to find out. He has some stuff for sale in the LS classifieds, you can find him there and click on his name to pm him.
Old 04-17-10, 07:46 PM
SRV1
SRV1's Avatar
The screen name you provided is not valid.
James
Quick Reply: Wheel HELP in NY
