Sunvisor and door lock problems
I have a '90 LS 400. The driver's side sun visor does not go all the way up. It goes up about 3/4 of the way and just sags. How can I fix this? Also, when I try to unlock the driver's side door (no remote unlock), the alarm sounds. Usually if I keep trying to unlock it, it will stop. What's wrong and how can I fix this?
Guest
Posts: n/a
I have similar issues with my drivers side lock. The remote netry doesn't work anymore so I always use the key.
The first thing is that sometimes turning the key once to unlock it, unlocks all the doors-not what it's supposed to do. It's supposed to only unlock the driver door. Also I can just barely turn to unlock and it unlocks the door, I mean like centimeters...just barely moving it will unlock the door. ;-(
Also the rear passenger side door doens't lock. I have to lock the doors and run over to that side and open it, pull the handle, then push the lock in while continuing to hold the handle, then let go and close it.
It's a pain.
It's a pain.
Did you ever figure out how to keep the sun visor up? I just got my first car, a 1996 ES 300. It has the same problem. I tried velcro but it wouldn't stay on. I have looked for a replacement on ebay for months with no success.
bcorey
03-10-14 08:36 AM
vinh
07-03-09 10:49 PM
