Will a 96 A/C compressor work on a 92?
I got this at a salvage yard for a 100. going to use freeze 12 or 134 after I flush becouse my old one compressor grenaded. Also got a new receiver-drier and thermal expansion valve. Thanks
no it wont...plug is different for one thing.471162 is a 92 denso part number,4711220 is a 96 denso part number(rock auto). i wouldnt use freeze 12 it sux. u had better vacuum the system out,then flush it.if u r planning on keeping the car then get a reman denso and do it right.......good luck
The reason that I was asking was because I have seen a couple of them on the Internet that say 1990 through 2000 with the part number of NIP080973L Remanufactured Nippondenso 10PA20C Compressor
Shaft: Splined
Cross Bolt
Switch: Yes (Rear)
Type: Lexus
Number of Grooves: 6
Clutch Diameter: 4.74"
Mounting Distance: 0.32"
I have an electric vacuum pump and gauges. thanks python
I can change the plug. maybe I should use my old speed sensor . At least I know the new compressor can handle 134a head pressure are you sure about freeze 12 all of the little bit of information I have been able to find about it sounds too good to be true!
Shaft: Splined
Cross Bolt
Switch: Yes (Rear)
Type: Lexus
1996, 400, 92, ac, accompressor, air, change, compressor, conditioner, conpressor, expansion, flushing, lexus, location, ls, ls400, thermal, valve, works
