The LS400 that died! FML
Old 05-01-10, 07:23 PM
LSWhat
LSWhat's Avatar
Fixed and running like a charm. Thanks guys! Yeah I used a whole big roll of electrical tape after splicing the wires and wrapped it up good. Punched holes in the lips of the inner fender strung it up as high as it could with zipties. Should not have any problems now, gonna keep a care full eye out for bumps now!
Old 05-02-10, 12:16 PM
skperformance
skperformance's Avatar
He has a pre 95 which does not have the same harness in the wheel well to rub under excessive drop . Only 98-00 have the issue , no one with a 95-97 with less electronics has complained .
Look for a loose ground or connector by the coils.
Old 05-02-10, 12:30 PM
LiCelsior
Retired
LiCelsior's Avatar
wonder where u got that info from? there's a harness in both fenders wells....
Old 05-02-10, 03:27 PM
LSWhat
LSWhat's Avatar
Well either way I fixed it better than it was! Lol
Old 05-02-10, 08:02 PM
5ofakind
5ofakind's Avatar
Why not put std wheels & tires on it.....& not have that problem at all....
Old 05-02-10, 09:23 PM
skperformance
lil , I have never read of 1 gens complaining of this issue other than this thread , did yours have it requiring the fix ?
I also did not read it completely where he said it was rubbing it .
5ofa kind .......?
You obviously pride your self on being stock or being just good enough.
I prefer (as many do) to exceed just good enough to there own preference .
If we all preferred rolling stock we would all be driving horse draw buggies .
Know what I mean.
Old 05-02-10, 10:08 PM
LSWhat
LSWhat's Avatar
5ofa kind .......?
Know what I mean.
+1 I agree with this.
NJ240sxMan
NJ240sxMan's Avatar
Sk, it's common in 1LS's as well :P but no worries.
I have to also agree with sk though, 5ofakind. I would rather be driving hard and low on my 19's with rubberbands than toting around on my stock 16's with big fluffy tires. There's a reason I pulled the fenders as much as I did :P
Also, with my 19's I get superior handling and traction compared to my stock 16's even with my stretched tires. We are not including winter performance in this as I have a set of snow tires on stock wheels specifically for that purpose, but again that is performance tires on a stock wheel.
I may actually relocate my harnesses in my LS since I believe that MAY be what I am rubbing against when my front drops at all.
Out of curiosity, how many 1LS (UCF10) guys are still running fender linings when slammed? I want to try to maintain my fender lining even when the front is dropped as low as I can get it (for now it is trimmed). What would you suggest using if I was to make a new lining (metal flashing, plastics, thicker gauge metal, etc)?
Old 05-02-10, 11:23 PM
LiCelsior
Retired
LiCelsior's Avatar
yea i had to repair mine also.
Old 05-03-10, 10:29 AM
LSWhat
LSWhat's Avatar
Well all that mudguard is is plastic thats almost as thin as paper. I was pretty shocked at how thin it was. I guess if you tucked the harness up higher or just did a full relocation you would be fine, but to keep most of the mudguard and still be slammed, I would cut a good portion out of the top just so you aren't rubbing it at all. As a matter of fact that's what I might do.
Skorpos
06-19-14 07:38 PM
ctwitty
04-23-13 08:58 PM
evileagle
Performance & Maintenance
10-11-11 12:44 PM
DzaztrBUSE
12-11-10 01:07 AM
dlpalmer20
Maintenance
11-08-09 12:51 PM
Quick Reply: The LS400 that died! FML
