1990 ac compressor wont kick on
Hey everybody., i have a 90 ls400 and the compressor wont kick on it worked fine and cold and then all of a sudden it quit working. i changed the timing belt and checked the connection on the ac compressor ( one gray connector is that the only connection?) . i dont know whats going on , the guy i bought it from said that he just put $1000 worth of ac work done so im hella mad haha. any help would be overly appreciated thanks thanks thanks.
There should be two connections to the compressor. One is for the magnetic clutch and the other is the compressor rotor speed sensor mounted on the rear of the compressor. When you turn the A/C on, does the A/C light blink, or stay constantly lit?
Jeff
Jeff
okay so my front fans werent working either, i popped out the headlight checked the relays and what i found was one of them if i barely press it down it will click and activate the fans but if i put it all the way down it wont. Why would it do that? thanks
okay i checked the wire thats on the fireall that changes direction when put from heat to cold and it does that too. the clutch and the compressor arent kicking on.... im clueless i cant find the switch on the back of the compressor and the front one appears to be plugged in . any suggestions? i tried to add freon to no avail.. thanks and the a.c. light isnt blinking
i dont know what that means but mine turned out to be a massive leak i still havent found yet i replaced the o-rings on the lines into the compressor and checked the gasket that sandwiches the mounting place for the lines and it appeared fine but ima replace it since the leak detector is going crazy around that and it is tight
NMCHUGH6
07-29-11 08:26 PM
