Anti freeze smell
Old 05-14-10, 09:36 AM
deanshark
deanshark's Avatar
Default Anti freeze smell
I'm just wondering if this would be the heater core? I got the antifreeze smell inside when the heat temp is turned up to about 75 or higher even though the heat doesn't work. It hasn't since I bought it. (7 months ago) If the heat is off and it is set to fresh air I can smell it until I switch over to recirculated air, so it is just when it is blowing. This just started a few weeks ago. I thought the heater core was good b/c both the in and out hoses under the hood would get hot, even though I had no heat. If it is the heater core, how hard is it to change, how much of the interior has to come out?
TIA
Old 05-14-10, 09:44 AM
TWong350
TWong350's Avatar
Could be the heater core. Most cars, the dash needs to come out to swap the heater core. Definitely not a fun job. You'll also need to evacuate the a/c system as the expansion valve is mounted on the heater core, typically. You could have a slow leak causing you to smell it. Pressure test your cooling system and see if you it's holding pressure ok.
Old 05-14-10, 09:49 AM
deanshark
deanshark's Avatar
I didn't think the whole dash had to come out, just the under side. I do have to pull the radio also, and the cabin filter so I might as well do all at once. The A/C works but it's not ice cold and it takes a long time to get cold.
Old 05-14-10, 03:10 PM
TWong350
TWong350's Avatar
Well, you could be right. I've never pulled a dash out of an LS. I've done many Toyota's and have always had to pull the dash. When I did my 240SX, I didn't have to pull the dash. Just depends.
Tabaka
SC- 1st Gen (1992-2000)
06-01-16 09:53 AM
TunerLexx
11-16-10 10:11 AM
v-empire
17
01-29-10 02:39 AM
mvbls400
12-06-09 10:23 AM
trangk
Performance & Maintenance
11-24-08 08:45 PM
Quick Reply: Anti freeze smell
