How do I disable the factory alarm on 1990 Lexus ls
Just bought a used 90 Lexus ls and I want to disable the factory alarm. I dont have the key that has the alarm buttons. Just the spare. Is there a wire I can just disconnect? Please Help!
So this wire I just need to cut and ground it out? Every time my car sits for more than an hour, when I unlock the door with the key the alarm goes off, and 9 times out of 10 scares the **** out of me, just started doing this a couple weeks ago..
No aftermarket alarm that I know of, or have seen. And I've had pretty much the whole drivers side of the dash torn apart. I ground the only solid green wire I could see, it was going into a blue plug. Not sure if it worked. When I lock the door, the security light is still illuminated, though, it stays solid whereas if i remember correctly, it blinked before. Is this right? I guess i'll see in the morning if my alarm goes off, car usually has to be locked a couple hours for it to happen.
Could you be more specific? Maybe what plug it goes into or a picture? I ground the only solid green wire I found, and still didn't work. I couldn't even get my alarm to disable this morning, so i couldn't start my car and had to get a ride to work
do you know what a kick panel is???
have you removed it???
did you find a solid green wire???
have you grounded it???
http://www.modifiedlife.com/1990-lex...llation-guide/
Factory Alarm Disarm Wire (-): Green
Factory Alarm Disarm Wire Location: In Drivers Kick Panel.
that should do it.
that should do it.
i would undo whatever u have done so far..and start from scratch, the kick panel is located to the left of ur left leg when ur driving..u know that foot rest thats located when u stretch ur left leg out? the kick panel is located right there..just a little towards the door. i dont know what else to tell u..there is a solid green wire..no stripes on it.
