Poor gas mileage 1990 ls400 84k miles
Old 06-05-10, 06:33 PM
bravonext
bravonext's Avatar
Default M p g' s
My car if f--ed up then, how in the world canyou get more mileage out of your mpg's then the epa estimate? I just have to change my spark plug wires and distributors coils to see if it improves...
Old 06-06-10, 01:21 AM
avalon42
avalon42's Avatar
I dropped my hydraulic fan and put in two electric fans. Most of my miles are freeway when I'm getting 400-420. That fan adds power and frees up some lbs so the engine runs better.
Old 06-06-10, 11:53 AM
Thermactor
Thermactor's Avatar
Originally Posted by avalon42
I'm at 210K. Replaced my plugs, wires, rotors, caps, both coils, and my two main O2 sensors. Warp speed restored.
If your car has warp drive, mine has transwarp drive.
"All automates ready and functioning,
automatic moorings retracted,
all speeds available through transwarp drive."
"Incredible machine."
Old 06-06-10, 03:11 PM
avalon42
avalon42's Avatar
"Up yer shaft."
RIP James.
Old 06-06-10, 09:02 PM
Legionofon
Legionofon's Avatar
Change your Coolant Temp Sensor, you might have timing off if its as bad as you say... i went from 14-15 mpg to 23 with a CTS but if your having serious problems past that might be something else...
Old 06-07-10, 08:31 PM
bravonext
bravonext's Avatar
Originally Posted by legionofon
change your coolant temp sensor, you might have timing off if its as bad as you say... I went from 14-15 mpg to 23 with a cts but if your having serious problems past that might be something else...
just by changing the cts?... Even if theres no warning lights going off?
Old 06-08-10, 09:35 AM
Boyscout
Boyscout's Avatar
replace:
O2 sensors
fuel filter
coolant temp sensor
Plugs
Wires
Rotors & caps
clean:
injectors (additive)
Old 06-08-10, 01:06 PM
Brandicus
Brandicus's Avatar
just dont try and go to warp 10 and get f'ed up and have alligator babies. (acutal episode of votager)
Old 06-13-10, 12:08 PM
g3t0ut
g3t0ut's Avatar
Originally Posted by LiCelsior
hmm, im constantly getting around 300 each tank, and i drive like 50-60 everywhere.
im in the same boat man, if im lucky i get 350.. idk what to do :/
Old 06-13-10, 06:30 PM
lowKut
NELOC Moderator
lowKut's Avatar
I had my LS for over a year now and never really monitor the MPG im getting. I actually filled her up yesterday so i might have to reference back to this thread later.
Old 06-19-10, 01:56 PM
bravonext
bravonext's Avatar
Default Mpg's
Changed Caps and Rotors, filled gas tank and ran from 13.5mpg to 16mpg. It gave me just City driven no Highway at all, 303 miles whe the Low Fuel light lite. Need Spark Plug Wires now.
Old 06-26-10, 10:26 PM
bravonext
bravonext's Avatar
Default Mpg's
WELL THIS IS AN UPDATE ON THE MPG'S OF MY SEDAN. A LUCAS FUEL TREATMENT AND A FULL TANK OF GAS GAVE ME 17.78MPG OF THOSE 1/3 WAS HIGHWAY THE REST IS CITY AND NORMAL LIGHT ON THROTTLE ACCELERATING. A/C ON WHEN NECESARY AND TIRE PSI ON 35PSI(FACTORY SIZE RIMS AND TIRES). LETS SEE WHEN I DRIVE IT FROM ORLANDO TO MIAMI IF IT WILL GIVE 24+MPG. (EPA'S ESTIMATES)
Old 07-08-10, 03:14 AM
lowKut
NELOC Moderator
lowKut's Avatar
I finally monitored the MPG for the last two fill-up I did and the outcome is pathetic
City driving w/ AC on 99.9%...157 miles
Highway driving including little local driving in the mix/AC on ...257 miles
Is this consider normal for a 90 LS or is there something I can do to improve?
Old 07-08-10, 12:57 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
uhh dude, if you didnt measure the actual amount of gasoline used how did you figure out your mpg? giving us just miles traveled is only half-way there.
Old 07-09-10, 08:35 AM
lowKut
NELOC Moderator
lowKut's Avatar
on every fill-ups the tank was empty..1st gen ls capacity is approximately 16.5 gallons.
Quick Reply: Poor gas mileage 1990 ls400 84k miles
