No spark
Old 06-19-10, 09:08 AM
maxgee
maxgee's Avatar
Default No spark
Car sat for a few days, go to start it and it just turns.
I checked the return line and fuel is there, pulled plug on right and left sides and no spark. Took the coil to Advance to be checked and it's working.
What else can I check?
Old 06-19-10, 02:03 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
no year = no help!
Old 06-19-10, 03:16 PM
maxgee
maxgee's Avatar
1995 LS400 with 240k miles
Old 06-21-10, 04:00 AM
maxgee
maxgee's Avatar
1995 LS400, no mods, completely stock with 240k miles.
update:
1. connected a scan tool, but no link successful.
2. swapped EFI and Main Engine relays around with other/no change in condition.
Any ideas?
Old 06-21-10, 04:50 AM
PureDrifter
BahHumBug
confirm that the ECU is getting +12v. if it is, then the ecu died. needs replacement/refurb.
Old 06-21-10, 05:18 PM
maxgee
maxgee's Avatar
I'm trying to find the site that has the wiring diagram, but unable to gain access.
Do you know which plug/pin is the power wire for the ECU?
Old 06-22-10, 11:27 AM
nthach
nthach's Avatar
Jumper terminals TE1 and E1 in the diagnostics connector in the engine bay or the circular one in the driver's footwell. If the CEL blinks, you got power. The fuel injectors shouldn't trigger if the ECU isn't grounding the relay for the injector ballast.
The 1995 cars are pre OBD-II compliant but the scan tool support can be iffy.
Old 06-23-10, 06:47 PM
maxgee
maxgee's Avatar
I Jumped the diag under the hood te1 and e1 turned the key
to on and no blink of cel just stays on.
Computer no good I guess?
Old 06-26-10, 07:51 AM
maxgee
maxgee's Avatar
Found a computer from a 96, will this work with a 95?
Old 07-12-10, 05:10 PM
maxgee
maxgee's Avatar
update
ecu was fried
got one from a 96, started right up.
ojahsan
13
06-21-15 09:52 PM
UNDR8D
21
09-26-12 04:57 PM
ImWildBill
22
10-07-11 08:18 AM
BlueLS
07-11-11 09:11 PM
RAINBOW
22
09-21-10 07:57 AM
Quick Reply: No spark
