Air conditioner squeal sound
Old 06-25-10, 10:00 AM
mark98ls40
mark98ls40's Avatar
Default Air conditioner squeal sound
Just got a 99 LS with 99k miles but the AC makes a squealing noise from compressor when turned on. Cools great. Is the clutch going or the whole unit?
Old 06-25-10, 11:36 AM
etex
etex's Avatar
Probably neither.... check the tension on your drive belt. If it hasn't been replaced, get a new one (not from a parts house) and put it on.
Old 06-25-10, 12:53 PM
rburg
rburg's Avatar
Could be the bearing on the compressor itself. Would check the idler first as etex suggested though.
Old 06-25-10, 02:23 PM
mark98ls40
mark98ls40's Avatar
It only makes the noise when the compressor engages. Would that make the tensioner bearing squeal? It sounds normal with no AC on.
Old 06-26-10, 11:26 AM
etex
etex's Avatar
It's not the tensioner bearing, but the drive belt that's squealing.
Old 06-27-10, 01:57 PM
mark98ls40
mark98ls40's Avatar
I will give that a try. Thanks.
Oh, the rpm drops about 50 - 100 when I turn the air on if that makes a diff. It stays lower & doesn't jump back up to normal after a few seconds.
Old 06-29-10, 10:33 AM
damon
damon's Avatar
If etex solution does not fix your problem try some BG Frigiquiet II if you determine the squeal to be emanating from the compressor itself.
It may turn out to be a cheap solution to your problem. Hard to find though!
yell0w
Performance & Maintenance
04-30-13 07:17 PM
jbone29
06-12-12 10:23 PM
Vortes
12
09-08-08 02:52 PM
bobolee
05-21-06 01:26 PM
whosdady
SC- 1st Gen (1992-2000)
06-24-02 12:41 PM
Quick Reply: Air conditioner squeal sound
