Door Won't Open..!!! HELP!!! 1990 LS400
1990 LS400 front passenger door. Couple months ago the outside door handle just stopped grabbing the mechanism in the door and wouldn't open it. Figured it didn't matter as I drive alone most of the time. I'd fix it later. Well, I wanted to fix it this weekend and the inside door handle doesn't grab anymore either. It was working as late as last week! So now the door is closed and I need to open it to get the inner panel off so I can see what needs to be replaced. But with both handles not working, what do I do?
I need an idea on how to open this? Coathanger? Any ideas?!?
Deuce b...I need help to..my 90 ls400 will not open from inside or out....need to know how to get door panel off when you cant open the door at all....or a way to get the door open....help
Cosmos83 (10-22-21)
You could try fully lowering the window then removing the external trim at the top of the door frame and then with a good torch see if you can access the door lock mechanism with some wire then try and open it.
Other than that a locksmith may be able to open it.
Cosmos83 (10-22-21)
Not for a Lexus but....
http://www.wonderhowto.com/how-to-op...hanism-239213/
" a good torch " Queens English for flashlight.
Duece and ken, you're going to need professional help with this...... make the call.
Then again, what if you followed just steps 1 and 2 of this tutorial:
http://www.lexls.com/tutorials/body/fdoorpanel.html
In which you might be able to use a pair of long needle nose pliers to pull the rod going to the latch to open it. Unless it is at the latch that it's broken.
Hey duece ....got mine fixed today.....what it is ,is a spring broke in the door lock asemb...u have to take the lock assem out and its a pain but can be done. if you have not got yours fixed yet email me or post me a message. i can instruct u what to do.I did take a few pictures and can post those, it will give u an idea what your up against...A guy at lexus gave me the spring he gets them from ace hardware,so it didnt cost me a penny to fix except my labor and time....Free luv that....The hardest part is getting the door open so you can take the door panel off....Let me know if u need more advice..
Cosmos83 (10-22-21)
Cosmos83 (10-22-21)
Cosmos83 (10-22-21)
I will try to post pics not any good at it...FIRST OF ALL NEED TO GET DOOR OPEN i wedged open the top door panel with a long 3/8extension down in door because u have to bend back the plastic covers that cover the lock. looking down at cover from top go to far right side where the spring is it might still be hanging there loose because it will be broke .u will see it in pics.after u get the top cover folded back take a small wire like a coat hanger or smaller if poss. and push or pull the 2 places where the spring is suppose to be hooked on the latch and pull door handle on outside when u moved each one of those...it will come open. oh also wedge something in the inside door handle to keep it opened because if not pulled open ,its hard to get down to the latch where u need to go . so wedge open the inside door handle to open position and the top of door panel right above door lock in the corner. i took pic of door panel with my phone but dont know how to put them on here. when u get door open take door panel off.got to take out window chanel bar next to lock assemb there are 4 srews one at bottom and 3 behind the window molding,u will see where the chanel runs up,lower window down to pull the channel out sideway then straight up from inside door.unhook the latch rods at 3 locations, careful not to break the plastic locks, be easy they flip open.unhook 2 wire connectors there at bottom of door and pull latch out. replace spring in which u can get at ace hardware or go to lexus. u need to take plastic cover off..i left mine off for next time it happens. Now put it all back in..it goes back in alot quicker than it came out. if you need more help send me a private mess with phone number and i will call you...I cant get these pics to loads can anybody tell me how to upload to this site Thanks hopes this helps...
i wish i new that i was going to post pics,i would of taken better pics start to finish...the door latch shown doesnt have the plastic cover on it,i took it off . Anyway im glad i did take these,it gives some idea what to look for.
