98 LS400 "CHECK VSC"---40k Miles
#46
Hi Everyone,
I recently purchased a 98 LS400. I was just turning into a tight parking spot at the local grocery store when it felt like abs or something was kicking in on the turning wheels. Only after I looked dow to pull the key out of the ignition I noticed 'Check VSC'.
There are no other lights on ...like Check engine light or ABS...etc.
I just have a SOLID red light beside the odometer and where the odometer is there reads a message 'Check VSC'.
I've searched this forum and I've seen people saying everything from faulty wheel sensor to bad O2 sensor to ETC...lol
I'm wondering has anyone had this message and solved it?
I just had the codes read today: 0 errors
Thanks so much
Thanks so much
#47
I own a 98 LS400 and for several years, I would occasionally get the check VSC light. I would normally follow the owner's manual instructions by disconnecting the battery and then reconnect and follow the manual instructions. About a month ago, I got the VSC light again and it would not go away after the procedure. Also, the emergency brake red light stayed on. I just found out what the problem was... I needed to ad brake fluid as I was running low. Problem solved!
#49
paulo57509 (08-01-24)
#50
I would still very much want to make sure there isn't some other cause.
boostinsc
12
04-12-14 08:51 PM
