Electrical problem! Radio, p/mirrors, dome, trunk release, etc... HELP!
I have a strange electrical problem.
The radio quit working (yet I can open and eject the CD magazine), the dome light won't work, the electric trunk release won't operate, the power mirrors don't work, power door locks don't work, and the a/c won't remember the temperature it was last set at and each time the car is started it resets to 75 degrees.
Oddly enough, the electric release for the fuel door works, all 4 windows go up & down, the a/c/ works (just resets temp each time the car is started), and the headlights work.
If I forgot to mention something, I probably just forgot to test it out.
I checked all the fuses with a multimeter and they all tested as good. The fuseable links in the engine compartment look good visually.
Any ideas why all those components would go bad all at the same time? Could the radio headunit be bad and all those other things run through it?!?
Any ideas? Thanks in advance!!!
i have a strange electrical problem.
The radio quit working (yet i can open and eject the cd magazine), the dome light won't work, the electric trunk release won't operate, the power mirrors don't work, power door locks don't work, and the a/c won't remember the temperature it was last set at and each time the car is started it resets to 75 degrees.
If i forgot to mention something, i probably just forgot to test it out.
Driver side fuse box under dash, i had 2 blown. And under the hood right next to coolant reservoir there is another fuse box an i had 1 blown there. Check real good both sides of the fuse with the tool. And everything worked again.
I checked all the fuses and fuseable links. All are good.
I am now thinking maybe there is a common ground for all those accessories? Maybe that came loose?
