Fuel Pump Relay 91
Old 07-25-10, 03:04 PM
hobojoe
hobojoe's Avatar
Default Fuel Pump Relay 91
So here it is all..... Went to start the car this morning and it was TOTALY DEAD, the auto tilt didnt even move. So after jumping the car which has a 1 month old battery and then turning the car off again I could hear something running in the engine bay. Opened the trunk and could hear the fuel pump running also!
I did some searching and have seen some people have had this problem but couldn't really find a rock soild answer. So it's the weekend and right now everytime im not driving the car I have to pull the fuel pump relay to get it to stop so it wont drain the battery
Any ideas?
Old 08-30-10, 03:40 PM
hobojoe
hobojoe's Avatar
Well Just an update I found a relay online was only $8.00 from toyota it's 83.00. So I bought it just to try and no dice. Anyways just got my new Denso fuel pump and filter today FYI you can get these ordered at Autozone about 200 less that from Toyota. I will be replacing this weekend and will let ya'll know if that fixed the problem.
Old 08-30-10, 06:02 PM
JimsGX
JimsGX's Avatar
Any ideas?
What was it that was running in the engine bay? Did you check the fuel relay resistor out?
Old 08-30-10, 09:36 PM
hobojoe
hobojoe's Avatar
You could hear the whole fuel system running the fuel pressure regulator valve in the engine bay was making noise. I Plan to check it but have no idea where it is other that somewhere near the relay.
Old 08-30-10, 09:40 PM
JimsGX
JimsGX's Avatar
It's right below the fuel pump relay box, bolted to the passenger wheel well...
Old 08-31-10, 10:27 AM
hobojoe
hobojoe's Avatar
Jim thanks for the info, it's not looking to good so I just ordered a new resistor from Sewell.. 47.00 plus shipping with a CL account. I will let ya know if this fixes it and will hold off on the fuel pump until I have tried this.
NateDegram
08-13-17 09:45 PM
DoctorC
08-23-12 03:34 AM
cardwielde
Performance & Maintenance
01-22-11 06:21 PM
TroySC300
10-24-09 11:11 PM
whitels
Performance
13
03-24-06 04:41 AM
Quick Reply: Fuel Pump Relay 91
