How do you Enable The DRL (day time running lights)?
1 Post
Agreed Canadian tire might be a validate source to get it inspected but they have absolute morons working there.
For my 98 LS the DRL relay is under the drivers side headlight beside the 2 fan relays . The headlight has to be removed to access it.
Also my "lights on" indicator only comes on when I turn atleast the parking lights on , the DRL's have no indicator .
The main differences of the Canadian spec headlights is all are HID and they have washers . Which adds a diode to activate the washers only when the headlights are on. How do I know , I just blew my diode and it has no part number to order after being on the phone for an hour with Toyota Canada trying to get one.
A simple wiring relay can be made so the car turns on the headlights on full when the car is started and the parking brake is off.
Using those add a DRL kits are dicey as they don;t work that great at 1/2 the voltage all of the time. Better to have it activate your headlights fully on instead.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Also according to Kansas "The U.S. specification 1998 LS400 did not have DRL ... it was added in 1999."
skperformance did you do the DRL on your ls400 by yourself?
1 Post
I just spoke with the parts dept at a Lexus stealer. They have told me that I have regular headlights..NO HIDs.
Last edited by lexuslspro; 07-29-10 at 02:15 PM. Reason: I have regular headlights
1 Post
Thanks PD. I just checked. Those letters are no where to be found. I also neglected to mention the dealer used my VIN number to come to the conclusion that I don't have HIDs.
Thanks for that!
Thanks for that!
You can get a relay kit , add it to your fogs instead and use them as day time running lights . You could even make them hid's instead.
Simple as using a hot wire once the car is started and about $250.
Try this
https://www.clublexus.com/forums/ls4...-in-ucf20.html
enable by reconnecting those wires if they are cut.
Well having experienced 3 collisions from people turning left in front of me at the last moment, during the day with no headlights of mine on, I figure this is a pretty good law. Had I had headlights on I surely would have avoided at least 1 or 2 of those accidents--perhaps all 3.
lenunn1923
14
07-31-13 07:13 PM
