DIY Alternator replacement?
Old 08-02-10, 07:51 PM
dbaze25
dbaze25's Avatar
Default DIY Alternator replacement?
So tomorrow I'm going to be replacing the alternator on my 95 ls400. It gave out saturday and left me stranded in the mountains. I was able to make it home by going to autozone, getting a loaner battery and having mine charged, then drove through rain and fog down a mountain with no headlights, windshield wipers, ac, ect. I managed to make it about an hour and a half on one battery then i switched to my backup under a bridge on I-85. So now I've bought a new alternator and i plan on replacing it my self. Can anyone give me some advice on how to do this? I can't find a tutorial here or anywhere else. I'm not a complete noob mechanically, but I'm nowhere near an expert.
Old 08-02-10, 10:23 PM
sexul29
sexul29's Avatar
Here you go hope it helps http://www.lextreme.com/alternator.html
Old 08-03-10, 12:51 AM
dbaze25
dbaze25's Avatar
I mean thats a pretty decent one but i was hoping for something with more pictures...I've already seen that one. Thanks though
Old 08-03-10, 09:48 AM
dbaze25
dbaze25's Avatar
alright i really need some help here guys. I've started trying to change the alternator, but i cannot turn a single bolt. They're all frozen. I did some research online and the only helpful advice i got was using some wd40 and that didnt help. I dont have room for a breaker bar and laying on my back i just dont have much room. someone please help me.
Old 08-03-10, 01:59 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
honestly at that point you need to take it to a shop. there's ALWAYS room for a breaker bar or an impact wrench on the 1uz, and no real situations require an impact wrench
Old 08-03-10, 02:02 PM
dbaze25
dbaze25's Avatar
cant get it to a shop without getting a tow. and i dont have money for a tow or a shop.
Old 08-03-10, 03:24 PM
PureDrifter
BahHumBug
then find a friend with more experience working on cars.
Old 08-03-10, 03:45 PM
dbaze25
dbaze25's Avatar
so helpful.
Old 08-03-10, 04:37 PM
JimsGX
JimsGX's Avatar
Have you done this?
"Alternator will come out the bottom. You need to loosen the power steering pressure hose from bottom. It connects to oil pan area with 3 10MM bolts. Once you loosen PS line you can remove from bottom without removing any other items. As you remove you will have to roll alternator as removing to clear the battery terminal on side of alt."
If that doesn't work, look this guy up...
Old 08-03-10, 04:49 PM
LiCelsior
Retired
LiCelsior's Avatar
its 3 bolts...put some muscle into it.
Old 08-03-10, 05:00 PM
rob22
rob22's Avatar
The attached might help, it's for a 2000 but the location is similar. You don't need to remove the P/S pump.
It's not hard to replace, in fact one of the easiest alternators that I've swapped out.
You have the front end raised properly...right? Jackstands, wheels blocked etc?
File Type: pdf
Old 08-03-10, 08:20 PM
dbaze25
dbaze25's Avatar
Originally Posted by JimsGX
Have you done this?
I didnt see any need to do that...The PS line wasnt in the way.
Three bolts that havent moved in 15 years. I've got plenty of muscle, but I dont want to round of the bolts.
Yeah, i have the front end up. Thats a really good diagram, but at this point i've already figured out how to take it out, its just actually getting the bolts out that i'm struggling with.
So nobody knows any clever ways to get a frozen bolt out with limited space? I went to the store and got some liquid wrench, but that did me no good. I've thought about heating it with a mapp torch, but i'm worried i'll set something on fire down there.
Old 08-03-10, 09:41 PM
valex
valex's Avatar
I replaced mine last fall (1999 LS), 10 years (not 15), but those bolts weren`t so hard to undo, I don`t remember any struggle.
Old 08-03-10, 09:52 PM
PureDrifter
BahHumBug
seriously, a 3ft breaker bar and some leverage will have no problem breaking those bolts.
Old 08-04-10, 12:32 AM
LiCelsior
Retired
LiCelsior's Avatar
ive removed an alternator from a 92 LS..didnt round off anything nor did it take that much effort.. use a 6point socket and ur fine.
Quick Reply: DIY Alternator replacement?
