Error Code 21 (Left Front O2 Sensor)
Getting check engine with above code (1990 LS400). Replaced O2 sensor on drivers side with Lexus OE sensor. Still getting the code. It also sounds like there is a slight leak somewhere in the exaust near the manifold on the same side. Would this cause the Error 21? or is their something else I should look for?
as per this post
http://us.lexusownersclub.com/forums...hl=error++code
error 21 is for "Solar Sensor Circuit"
BahHumBug
as per this post
odd question but have you ohmed out the TPS? it seems that the generic OBDI code 21 is a TPS code, but lexls has it listed as a bank 1 no.1 O2 sensor?
