Steering Wheel Tilt Motor
Old 08-12-10, 09:09 AM
ravig292
ravig292's Avatar
Default Steering Wheel Tilt Motor
My 2000 Ls400 Steering Wheel motor is messing up. When i put the key in the wheel goes down a little bit then stops. It is supposed to go lower than that so i press my memory button the wheel goes down a little again and stops. I have to keep pressing the memory until it gets to my spot. also when i use the 4 way telescopic button it only goes up and down it wont go in and out.
What Should I do?
Old 08-12-10, 10:53 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
search. common issue, can be a potentially easy fix.
Old 08-12-10, 11:01 AM
7schulz
7schulz's Avatar
There's a video on utube about how to fix the up and down. The gear inside is slipping more than likely. Mine telescope didn't work either. That is a hole other issue. Good luck.
Old 08-12-10, 11:31 AM
Lexkost
Lexkost's Avatar
Is the telescopic motor the same as the up and down motor?
Aytex
07-19-18 06:21 PM
willcrets
13
02-28-18 05:55 AM
OMAHA
05-29-14 12:59 PM
GOLDSc300
SC400 / 300 Classifieds
10-05-04 03:11 PM
jjr1295
05-27-04 07:50 AM
Quick Reply: Steering Wheel Tilt Motor
