93-94 LS Headlights Fit a 90-92 LS400???
Just a quick question. I wana swap my old school looking Headlights to get these Clear Lens(Euro Crystal Clear) Headlight assembly i saw online, But the problem is the add said it's for a 93-94 LS400. Will the Headlight Assembly fit my 92???? Thanks, everyone. Any info would be greatly appreciated
If your talking about Eagle Eye's, then yes, they're spec'd for 93-94 but will fit the 90-92...
Just be aware that a 90-92 uses a 9004 headlight bulb and the 93-94 uses a 9003 bulb. You'll need to find an adapter, or cut off the 9004 socket and wire in some 9003 sockets. Or if you have the $, buy a bi-Xenon HID kit for a 90-92 which will have the correct wiring harness for your car, and see if they'll give you a set of 9003 bulbs with it instead of the 9004's that would typically come with the kit. Steve from xenondepot.com may be able to accommodate you...
