How to remove glove box
Old 09-02-10, 11:51 AM
ae80siq
ae80siq's Avatar
Default How to remove glove box
Noob question but I'm trying to install a Datasystem on my '94 and I know the harness I need to get to is behind the glove box. I don't want to bust any clips or anything because I've never worked on the interior of newer cars. Thanks
Old 09-02-10, 12:29 PM
williamb82
williamb82's Avatar
remove the cov er on the left side, unscrew the 2 screws holding the yellow thing to it. then pop out the 3 round plugs on the bottom of the glove box. i also think there is 2 screws on the top side of it, not 100%. as for the glove box door, pull the covers off where the arms attach to the door. then slide the arms off by slightly pressing away from the door. then the center piece should slide out.
for the bottom piece on the passenger side, it snaps down from the middle with a flat head screw driver, then slide it toward the floor like an inch and it falls off the bottm and can be pulled out. then the middle part has 4 10mm bolts holding it on. 2 from the bottom and 2 that are behind the glove box once slid out. this middle piece has the ecu attached so unplug the ecu connectors from underneath before unbolting it to make it easier. youll then have full access to everything pretty much.
Old 09-02-10, 12:49 PM
ae80siq
ae80siq's Avatar
Thanks man you're the ****!
Old 09-02-10, 01:25 PM
williamb82
williamb82's Avatar
so was there 2 screws in the top of the glove box? mine didnt have them, but i pulled a glovebox from a 90 that did. mine might have just been missing from a previous owner pulling it. idk.
Old 09-02-10, 01:49 PM
Asia-H.T.
Asia-H.T.'s Avatar
On a 1993-1994, the same press-in-plugs as on the bottom should be on the top side.
Old 09-03-10, 05:09 AM
williamb82
williamb82's Avatar
gotya, mine didnt have anything there. so i didnt know if it was screws or what that were missing. didnt feel like crouching down in the floorboard to look up to find out either. lol
leonrojo18
07-19-21 06:06 AM
whokidd
10-05-13 07:21 PM
ihiryu
SC- 1st Gen (1992-2000)
07-28-12 05:02 PM
SkulCracka
12
11-29-11 11:22 AM
JOEYD2008
04-09-10 01:12 PM
Quick Reply: How to remove glove box
