Projector Project
Old 09-07-10, 09:59 AM
akitomk3
akitomk3's Avatar
Good job!!! can't wait till the finished product, can you post pics of cut off lines whenever you're done?
Old 09-08-10, 04:25 AM
qewani1
qewani1's Avatar
Lexkost,
what are the differences between gray putty and silicone ?
Old 09-09-10, 05:35 PM
Lexkost
Lexkost's Avatar
Pics of lights on car:
Attached Thumbnails Projector Project-heads-in-car-002.jpg   Projector Project-heads-in-car-001.jpg   Projector Project-heads-in-car-004.jpg
Old 09-10-10, 12:42 AM
emoshun
emoshun's Avatar
How did you wire your harness as to keep the lows powered when engaging the highs?
I have a pair of hybrid TL/ZKW's that I would love to retro into a pair of clear headlights like yours.
Old 09-10-10, 04:23 AM
Schnitz
Schnitz's Avatar
Lookin good. Hows the light output?
Old 09-10-10, 10:58 AM
RA40
Super Moderator
RA40's Avatar
Looks good Mike.
Just an FYI about your lower driving/fog lamps and fogs built into the headlamp housing.
I was stopped some years back for having more than four lamps on while on a public roadway. He cut me loose with a warning luckily.
V C Section 24402 Auxiliary Driving and Passing Lamps
Auxiliary Driving and Passing Lamps 24402.
(a) Any motor vehicle may be equipped with not to exceed two auxiliary driving lamps mounted on the front at a height of not less than 16 inches nor more than 42 inches. Driving lamps are lamps designed for supplementing the upper beam from headlamps and may not be lighted with the lower beam.
(b) Any motor vehicle may be equipped with not to exceed two auxiliary passing lamps mounted on the front at a height of not less than 24 inches nor more than 42 inches. Passing lamps are lamps designed for supplementing the lower beam from headlamps and may also be lighted with the upper beam.
V C Section 24405 Maximum Number of Lamps
24405. (a) Not more than four lamps of the following types showing to the front of a vehicle may be lighted at any one time:
(1) Headlamps.
(2) Auxiliary driving or passing lamps.
(3) Fog lamps.
(4) Warning lamps.
(5) Spot lamps.
(6) Gaseous discharge lamps specified in Section 25258.
(b) For the purpose of this section each pair of a dual headlamp system shall be considered as one lamp.
(c) Subdivision (a) does not apply to any authorized emergency vehicle.
Amended Ch. 234, Stats. 1976. Effective January 1, 1977.
Old 09-10-10, 11:46 AM
Lexkost
Lexkost's Avatar
Thanks Mike for the info,but the small bumper projectors are my fogs and can only come one with my headlights. The upper fogs come on with the highbeam switch and then all other lights are off. So I can use those upper fogs as a DLR but at 100% voltage......
Buy the way I will get some night pics up soon.
I was next to a LS430 the other night and my output was much better and wider, I am running a 5000K bulbs.I believe it is do to the custom lense and the rechroming of the bucket.
Old 09-10-10, 05:34 PM
RA40
Super Moderator
RA40's Avatar
That's a good light combo. Don't want the LEO's to take the fine comb and nit pick in the event the car grabs their attention.
I like the 430 projectors...will be interesting to see your night pics.
Old 09-11-10, 11:09 AM
Raddison
Raddison's Avatar
I love the stance of your lex, and I can't wait to see these lights at night!
Old 09-24-10, 09:36 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Looks great!! Thanks for the repeat business. Let me know how the Philips D2S bulbs work out for you.
Steve
Old 09-24-10, 01:27 PM
skperformance
skperformance's Avatar
Very nice , I think the fogs closer to the original spot on that bumper would give it a nicer stance . Now if you could make a matching housing for the fog lights as the headlights it would be mint.
Old 09-24-10, 02:13 PM
Lexkost
Lexkost's Avatar
If I ever get some original fogs and the corners I would clear them and do it.
I have a number of small projectors that would fit.
Buy the way SK I will be in Buffalo for Xmas, visiting my family !
Old 09-24-10, 02:23 PM
skperformance
Let me know when you are around I usually head out there to go shopping at Burlington coat factory before the holidays.
I would not wast time clearing the oem fogs. Use the template you have and cut some clear lexan , and use another fog light or headlight inner shroud for a more complete look to match your headlights better as they have there own unique style.
Old 01-09-11, 01:02 AM
RA40
Super Moderator
RA40's Avatar
Awright Mike... I'm going to poke you again...
Can you snap an evening pic from the driver seat so we can see the cut off.
Old 01-17-11, 04:08 PM
dc2loco
dc2loco's Avatar
willing to sell me a pair?
Quick Reply: Projector Project
