throttle body Plate issue
LS400 2000 model,
I have noticed that throttle body Plate does not open fully at all. I think something is wrong? any one have same problem.
This is the maximum throttle body Plate opening in my car when i turn using hand the throttle linkage to maximum open position.
My problem/question is similar to what this person having.
http://www.youtube.com/watch?v=I3xXifUAd18
i had seen several videos on youtube about throttle body, i have noticed that all of them opens maximum with full acceleration pressed. what could wrong with my car?
BTW no CEL/DTC.
BTW no CEL/DTC.
i could not find any lexus throttle body videos on youtube. Opening is done manually by turning the throttle butterfly.
PureDrifter,
you have LS400 why don't you check your car' s throttle body and report back.
PureDrifter,
Repair manual says that standard throttle valve opening percentage with full accelartion applied should be 60% or more. but in my car its not more than 25%
http://home.student.utwente.nl/gombe.../SFI/sf-36.pdf
![](http://img826.imageshack.us/img826/6500/second.png)
I have googled for this issue. I don't know what could be the problem. any suggestions?
billy if you could use obd2 scanner and read the "absolute throttle position" value with full acceleration applied and report back?
, thanks
, thanks
Many thanks in advance for your reply.
Tjfaz
03-18-13 04:09 PM
