No spark, No fuel, No run
Old 09-14-10, 08:54 PM
willhickey
willhickey's Avatar
haha your the man dude i appreciate your guide through if it wasnt for you i would have junked ours and started on a new project haha
Old 09-16-10, 08:58 AM
RAINBOW
RAINBOW's Avatar
Default Found the problem
I checked the crank sensor/wires just like Rolexus400 suggested, and what do I see but the sensor dangling from it's wire no longer attached to the engine. Easy fix ? Except that the crank pulley has spun in half and walked back into the sensor grinding it's plastic mount into goo. So now I need a new crank position sensor and a new/used crank pully (harmonic balancer). Is it Miller Time yet ?
Old 09-16-10, 10:36 AM
williamb82
williamb82's Avatar
damn, that sucks. well, at least you found the issue. guess while im rebuilding the starter 2marrow ill check my pulley and crank sensor out just to make sure im not gonna have a similar issue soon.
Old 09-16-10, 12:12 PM
RAINBOW
RAINBOW's Avatar
Thumbs up Don't wurry bout it
Williamb82, you don't have to check the pulley and sensor, they only fail on every 12th millionth car....... and that was mine ! Good luck on the starter, I'll say a prayer.
Old 09-16-10, 12:22 PM
williamb82
williamb82's Avatar
lol. thanks. i dont think itll be too bad. i dont plan to remove it, but if i have to i have a 24in extension and several 9-12in extensions so i can get the bolts with the ratchet by the back of the trans like i would a trans swap. fun part is gonna be removing and reinstalling the intake manifold.
Old 09-16-10, 03:15 PM
ROLEXUS400
ROLEXUS400's Avatar
rainbow-thanks for the call i checked my parts bin and i do have a balancer and a crank sensor,going home to talk to the wife. we may make a road trip to come see you and deliver the parts in person. ill call you tonight
Old 09-21-10, 07:24 AM
RAINBOW
RAINBOW's Avatar
Default Update on no run problem
Well Rolexus400 was right again. Pulled the skid pan crawled under and looked up at the crankshaft position sensor to check everything and found the sensor dangling, no longer attached. The crank pulley(harmonic balancer) had spun apart and wiped out the sensor, which killed everything. When Rolexus400 found out what I needed, he and is wife made a road trip to Roanoke and brought me the sensor and pulley. Amazing ! You guys that live in and around Tidewater that are having problems with your cars should give him a shout, before you **** away hundreds of dollars on unneeded parts and service. He has a co-pilot (his wife) that knows more about these cars than I do).Thanks for everyones help, hopefully this will be it for a while. p.s. My condolences to williamb82 for his problems, wish it could have been an easy one.
Old 09-21-10, 07:57 AM
williamb82
williamb82's Avatar
glad yours is fixed. ill pull my motor this weekend and prolly reinstall it the weekend after. at least now i can fix other things that need it that i didnt want to mess with because of the difficulty to access.
arfghan
GS - 1st Gen (1993-1997)
03-04-14 08:34 PM
meetoo1
10-29-12 02:07 PM
bighead222
SC- 1st Gen (1992-2000)
07-09-11 02:41 PM
SC400-V8
Performance & Maintenance
16
03-01-04 04:35 PM
Bean
04-23-02 07:31 AM
Quick Reply: No spark, No fuel, No run
