need serious help car not starting 98 ls
Old 09-18-10, 12:30 PM
blkvip
blkvip's Avatar
Default need serious help car not starting 98 ls
just finished my air install on my 98 ls400 and go to start it and nothing you can hear the fuelmpump go on got new battery and can hear starter itsv like everything normal just not kicking overm the check vsc light came on but hasent come on since the first
Old 09-18-10, 02:51 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
check voltage and then go over ALL your wiring again. it's an electrical issue most likely, if not just a dead battery.
Old 09-18-10, 03:01 PM
blkvip
blkvip's Avatar
batterys new and the only wireing is fromn the control box to height controller which is all good
Old 09-18-10, 03:13 PM
PureDrifter
BahHumBug
you must have tapped the system somewhere to get power, go over those again, triple check that they're the right ones.
and make sure you tightened down the battery terminals+grounds
Old 09-18-10, 04:04 PM
blkvip
blkvip's Avatar
nope. i have 2 wires going to the battery, all the others are going to the controller thats it. enless the ground for the control box is doing something
Old 09-18-10, 07:14 PM
PureDrifter
BahHumBug
hmm, so let me get this right:
-recently installed airsusp.
-all electrical in the car works
-engine turns over (and you can hear fuel pump)
doesnt start at all or it doesnt stay running??
senapeSC
Performance & Maintenance
21
08-24-14 08:15 AM
04chrisjr
Performance
03-24-14 08:29 PM
JREAL
11-18-13 09:13 AM
jiimpman23
04-05-12 07:20 PM
ta1972
12-05-07 08:17 AM
Quick Reply: need serious help car not starting 98 ls
