93 LS400 Courtesy Light On Door and Rear Pillar?
Ok so i purchased some L.E.D's to replace the bulbs on each door and the one's on the rear pillar that turns on when you open the doors. driver side is fine, i thought the passenger side one's were just burnt out. turns out that they don't work at all. also noticed that the switch to adjust the passenger seat belt height also does NOT work. do they run off the same fuse? relay? i have yet to take the door panel off but figured if they all don't work then it must be related. i searched for this but did not find any related threads. any help is greatly appreciated
-Sean
-Sean
well im almost sure the door switch is fine because the door ajar light comes on when passenger side doors are open. it's just the lights on each door, seat belt switch and the one behind the rear passenger seat does not work. damn im stumped
Patrick92
02-25-15 08:06 PM
Kawai4eva
RX - 1st Gen (1999-2003)
01-17-13 11:12 AM
