1993 ls timing belt broke due to idler pulley bad HELP with cam ali
Old 09-26-10, 09:43 AM
slinky
slinky's Avatar
Question 1993 ls timing belt broke due to idler pulley bad HELP with cam ali
been to lexls and has great instructions for install but want to know about cam adjustment. How do I know if/or the cam will be 180 off when installing new belt.
I understand the timing marks and can find top dead center but thinking about cam, is it possible to to get this messed up or should i be safe knowing 2 rev of crank equal to one rev of cams so should not be a problem, meaning no way of goofing up cam as long as it lines up.
Help
Old 09-26-10, 09:58 AM
Och
Och's Avatar
As long as you line up the marks on the crank and both cams, you're fine, theres no way of goofing up. Also, the engine is non interference, so you can spin crank and cams independently of each other as much as you want.
Check out tutorials at lexls.com
Old 09-27-10, 07:19 PM
lex2001
lex2001's Avatar
Ditto what Och says. I just changed my timing belt on my own last week. Lots of good info in the attached links.
http://www.shastaanesthesia.com/Lexus/Page1.html
https://www.clublexus.com/forums/sc-...ion-notes.html
https://www.clublexus.com/forums/ls4...-question.html
Old 09-27-10, 07:30 PM
masagsxr
masagsxr's Avatar
Yep... Lots of DIY's out there.
Old 09-29-10, 08:19 AM
Trevorsls4
Trevorsls4's Avatar
im doing a full heads up rebuild on my lexus and ive owned it for a week its not so bad so far all though getting the exhaust mani's off i think will be the hardest part and seeing that i work for advance auto parts for a living parts arent so bad neither thanks for all the prvious d.i.y's they are what gave me the inspiration on my 1st ls400
Old 09-29-10, 01:31 PM
BlueLS
BlueLS's Avatar
The exact thing happened to me and i printed out the article on lexls.com and followed it and my car runs like a champ and surprisingly found everything instock at oreilly's from the timing belt kit with pulleys, the tensionor, to the water pump (all of which you should replace while you're there). Spent about $500 or so. The write up on lexls.com is awesome and has every detail and pics of everything.
Old 10-01-10, 08:54 AM
3UZFTE
3UZFTE's Avatar
Good luck, I would recommend if the head gaskets aren't toast, don't bother wasting your time. Removing the exhaust mani's isn't that bad, just the overall build can be a little tricky. You will need the usual 8, 10, 12, 14, 17, and 19mm wrenches and sockets, as well as you will need a 12 point 14mm socket to get the special head bolts out, I got mine as Lowe's for like $4, not to mention screwdrivers, a hammer, pry bar, and the other usual tools. It's a bit more complex, but it can easily be done by most grease monkeys. Just make sure you have a good torque wrench too, and know your torque specs.
I think I bought everything from Toyota and spent a little over $600, to be the $100 is worth the reliability. Lexls is awesome, and a fellow Minnesotian.
Old 10-01-10, 11:06 AM
BlueLS
BlueLS's Avatar
Yeah wish I could gotten parts from dealer but they had to order everything and o reilly's had them instock and needed the car running asap due to work and school but would definetly recommend dealer parts for sure. Oh and yes Lexls is awesome! lexls.com ftw
VOLZ1207
Maintenance
01-26-18 07:36 PM
SenecaRex
12-31-15 03:55 PM
RL93LS400
07-27-15 03:46 PM
gripmatic
05-05-10 06:29 AM
rmehuron
01-11-10 05:19 AM
Quick Reply: 1993 ls timing belt broke due to idler pulley bad HELP with cam ali
