97 LS 400 Timing Belt Replaced at 152k
All,
Just completed timing belt, water pump, and all ignition replaced on my LS 400 with 152K miles on original timing belt, water pump, etc.. Amazingly the old belt had only minor cracking! Yes, I had been inspecting it for the last few years, and finally did the job. Honestly I thought it was a very easy job, once you found all of the "hidden" bolt heads!!!
What a great way to save huge service bucks!
I'm not amazed. Timing belts on Lexus cars rarely break but are instead trashed (like mine was) when another part in the system fails. I hope you changed all the auxiliary parts (idlers, water pump, etc.) because the failure of one of those are what causes timing belt failure.
I also had a power steering pump leak, so replaced the o-ring on the reservoir and put a bolt in that IAC Valve port. I think the O-ring was my leak as it was very"D shaped".
It started right up and ran much quieter. The only thing I have NOT replaced is the fan belt idler pulley, and I am thinking I should do that too.
Jim: Are you saying that if one changes the other parts related to the timing belt and skip the timing belt if it looks good is OK; you should get a lot more miles from it? I can see
changing the aux items becuae they appear easier, and passing on the belt. All that lining up the marks and other steps on the belt may be more than I would want to attempt. MOre of your comments on this would be appreciated. Thanks!
Could you post the part No of all the OEM parts that you put in?
That would be very helpful.
Thanks
Thanks
All,
1997 LS 400 Parts List
Description Part Number Quantity Needed
Timing Belt 13568-59045 1
Water Pump 16100-50023-83 1
Water Pump O-Ring 96761-24019 1
Idler Pulley No.1 13503-0F010 1
Idler Pulley No.2 13505-50022 1
Timing Belt Tensioner 13540-50030 1
Thermostat 90916-03129 1
Thermostat Holder O-Ring 96761-35035 1
Water Pump Gasket 16325-62010 1
Spark Plugs 90919-01178-83 8
Spark Plug Wires 90919-22379 1
Distributor Caps (L&R) 19101-50020 2
Rotors(L&R) 19102-50020 2
Upper Radiator Hose 16571-50070 1
Lower Radiator Hose 16572-50090 1
Power Steering Pump Reservoir O-Ring 90301-11016 1
TO REPLACE VALVE COVERS
Valve Cover Gasket Set 11213-50021 1
Spark Plug Gaskets 11193-15010 8
Washer, seal 90210-07001 16
Form in place Gasket 00295-00103 1
Throttle Body Gasket 22271-50010 1
PCV Valve 12204-50011 1
PCV Valve Grommet 90480-18001 1
Awesome right up - thanks for the part numbers. I never did the job myself. I am coming up on my 3rd belt change soon. Even though they last well beyond 100k miles I feel better sticking by the published interval
I really enjoyed doing it....my wife thinks I am sick!
GeeTee
02-21-11 08:06 PM
kminev
Performance & Maintenance
02-03-10 06:16 AM
